po codes
4
i have a 2006 freestyle that came up with a po701 code
it have a cvt trains and is awd
the speed control setit off ,turn car off and speed control ,runs good
is the speed controler bad or is there a trains problom?
TCM has detected other transaxle DTCs setting this DTC enables limp home mode. Engagement concerns. Harsh/erratic.
No torque converter lock-up.
Lack/loss of power/acceleration.
Different ratio behavior (increased engine rpm).
Will turn on MIL and driver warning lamp.
FIX other transaxle DTCs first. CLEAR DTCs. If DTCs return, REFER to Diagnosis By Symptom in this section.
Title Routines
Engagement Concerns
No Forward 201
No Reverse 202
Harsh Reverse 203
Harsh Forward 204
Delayed/Soft Reverse 205
Delayed/Soft Forward 206
No Forward and No Reverse 207
Torque Converter Operation Concerns
Torque Converter: No Apply 240
Torque Converter: Always Applied 241
Torque Converter: Cycling/Shudder/Chatter 242
Other Concerns
Selector Lever Efforts High 251
External Leaks 252
Noise/Vibration — Forward or Reverse 254
No Park Range 256
Overheating 257
Surges (Ratio Oscillation) 258
Loss or Lack of Power or Accebration 259
4
the car runs good with out the speed control on,turn it on and all of those problem show up. turn car off and on,all is good then.
no other code p0701
is the speed contoler sending a bad singal to the trains?
