- 1
- 0
Help i replaced my rear window with a tinted slider and used the same black gu that ya use to change a windsheild but i just can't it to stop leaking 3 times so fare
Welcome to FTF!![]()
Sounds like you need to get a new seal for the window. I changed the rear window on my 1979 F250 and never had a problem with leakage even with the original seal..
Also you need to post tech questions like this in the appropriate thread if you expect to get answer.
A mod needs to move this.
You need some Mighty Puddy!
Great suggestion...not, OP don't try this.
Your about a bright as a brick, my cat got that joke, please lose the Mr Spock attitude, its annoying and your trying to hard to look smart, makes you sound like a little kid.
If your window is leaking get a new seal for it and that's about it.
