pinpoint test for P0455 (Escort)
Could somebody please post the pinpoint tests for diagnosing a P0455 code in a 1998 Escort sedan (2.0 SOHC engine, auto trans).
I believe it's an EVAP system code.
Thanks!
Its 18000 characters long. We are only allowed 10000 per post.
OK
Smokey suggested checking the filler tube for rust.
Any other suggestions of common issues to look for?
*Filler tube is making sense, though- as I'm thinking about it, it kind of seems that it's been less consistent in when it'll shut off the pump when I fill the tank since around when the light came on. Haven't had the car long enough to really be certain, but it just seems less consistent.
bowtiehatr
Certified Ford Tech
evap issues can be a pain. the systems need to be put under a pressure to see where the leak is. if i remember correctly the 455 code is a gross leak, usually a line loose or off, or even a gas cap.
Well...finding the problem didn't turn out to be as hard as was afraid it might be:
What would you call the piece that's cracked? Guessing this'll be either a dealer/junkyard part? Part of the filler neck or a separate piece?
*Also, any guesses how it broke? I'm thinking I must have hit something when I replaced the springs, but I guess I could have cracked it when filling the tank, too.
Thanks!
Okay, thanks!
