Parking brake components
after some long and hard thinking it is time to get a parking brake installed so i can ditch the wood block and the steel rod. where can these components be found at? i look @ Dennis carpenter and they didnt have them, LMC is my last ditch place if absolutely no one has them, EDIT**** bronco graveyard had only the cables and a retainer
Sorry, nothing to add, just subscribing to this because my Bronco doesn't have a parking brake either...and I need to find one too. On trucks, I've just setups from junkers.
How about posting the truck info I need to look it up and find it?
Here are the basics
D4TZ-2530-A = BRACKET
C6AZ-2A602-A = EQUALIZER
MM-173-K= NUT
D6TZ- 20635-C -RH 57 /18" LONG
D6TZ-2A635-D - LH = 65 3/4" LONG
D8TZ-2853 = CABLE 109 3/4" LONG
blackhat620
You Had to be There
1,687
150
Arizona
Also try your local wrecking yard.
