old POS .lol.
atcJESSEb
ocala
my mechanic told me that my truck is running on 7 of the 8 cylinders that it has, according to him there an oil leak and it making the spark pluge wet or somthing what should i do
.....and truck is knocking a bit when i get on the gas anything to help that?
remember ...300,000miles
Remove the radiator cap, and back a new truck under it!
surewhynot
Rep whores make me sick
13,843
821
Florida
Patch that sucker up and go another 100K. :D
You might be able to put a non fouler on the plug that is catching oil. As far as the knocking is concerned, turn up the radio.
surewhynot
13,843
821
Florida
On a serious note. It sounds like a rebuild is the only way to fix what ales it. You might be able to hide the knocking by switching to a heavy oil, but that may in turn cause other problems.
I once quieted down a main bearing knock in an olds 455 by changing the oil with straight 50 weight motorcycle oil. It ran smooth and quiet for 2 days before it blew.
If I were in your shoes, I'd try a non fouler on the plug and baby it along until you can rebuild or replace it.
lil_dq
Let 'er eat boys!
6,933
265
Union, MO
2 things:
1 if your spark plug is getting wet in the cylinder hole for the COP then it is prolly coolant. If it is getting wet inside the cylinder then you are screwed. and have to at least replace the heads and possibly the rings.
2 your screen on your oil pickup is prolly starting to get clogged. I would drop your pan and clean it out real good or just order a new pickup.
Just my .02 from the multiple times I have had my engine out.
atcJESSEb
ocala
haha thanks for the advice i think im just going to milk it for the next 6 months till i leav for basic thanks!!!
surewhynot
13,843
821
Florida
I'd say the first one off the Dyno would win. That would be anybody except Doc. :D
Sorrry Doc. :(
lil_dq
Let 'er eat boys!
6,933
265
Union, MO
Sorrry Doc. :(
rissa frassin mother fruckin cheese and rice sum itch grrr below the belt hittin ****&^%%$&$&^%*(&^%$&(%$.
thanks tony! LOL
