CAPofMD
Delaware Chapter member
Has anyone drilled their oil pan to install a temp probe? Even if you haven't but know of a SAFE area to do that, where would YOU drill a hole in your pan (not the bottom) to install a bung for a temp probe?
You all ready have an engine oil temp sensor. Its on top of the engine, behind the oil filter.Has anyone drilled their oil pan to install a temp probe? Even if you haven't but know of a SAFE area to do that, where would YOU drill a hole in your pan (not the bottom) to install a bung for a temp probe?
That depends on how much molten metal is accidentally dropped into the pan, doesn't it?the oil in the pan is the COOLEST oil in the engine.
