19E616
00092203
Customer Comments
CUSTOMER STATES NIOSE COMING FROM DASH WHEN
Tech Comments
TEMP CONTROLS ARE ACTUATED VERIFIED CUSTOMERS CONCERN TESTED FOUND AC MO DE CONTROL DOOR BROKEN HAVE TO REPLACE PART O N ORDER
Details
7385801
E83
25
.8
ST MARYS FORD
22667
28-FEB-07
5W7Z
12A647
A
00092202
Customer Comments
CUSTOMER STATES THAT TEMP GAUGE OUTSIDE TEMP
Tech Comments
SENSOR READING 145 WHEN ITS 25 OUT SHAWN VERI VERIFIED CUSTOMERS CONCERN FOUND THE AMBIENT TEMP SENSOR NOT WORKING PROPERLY REPLACED THE SENSOR TESTED VEHICLE OPERATES AS DESIGNED
Details
7395448
E83
25
.2
ST MARYS FORD
22667
28-FEB-07
17700
00092204
Customer Comments
CUSTOMER STATES AUTO DIMMING MIRROR LOOSE
Tech Comments
REAR VIEW VERIFIED CUSTOMERS CONCERN FOUND MIRROR LOOSE REMOVED MIRROR ADJUSTED REINSTALLED AND TIGHT ENED MIRROR TESTED VEHICLE OPERATES AS DESIGN ED
Details
9112786
E84
34
1.8
ST MARYS FORD
30302
03-DEC-07
7L3Z
2648
A
00363701
Customer Comments
CHECK CLUNK IN REAR END
Tech Comments
VERIFIED CUSTOMERS CONCERN FOUND THE E BRAKE CABLES ACTUACTORS STUCKON SEIZED REPLACED THE E BRAKECABLE ACTUATORS AND E BRAKE SHOES TES TED VEHICLE OPERATES AS DESIGNED
Details
9478261
E84
37
1.3
ST MARYS FORD
32920
22-FEB-08
7000
00427901
Customer Comments
CUST STATES TRANSMISSION SLIPPING
Tech Comments
COULD NOT VERIFY SLIPPING TRANSM THROUGH ROAD TESTING,PERFORMED A VISUAL INSPECTION,FOUND 3 PINTS LOW IN FLUID,REFILLED,OPERATES AS DESIGNED
Details
9478262
E83
37
.2
ST MARYS FORD
32920
22-FEB-08
13466
00427902
Customer Comments
CUST STATES LIGHT IN SHIFTER CONSOLE INOP
Tech Comments
VERIFIED BULB BLOWN IN SHIFTER,REPLACED BULB,OPERATES AS DESIGNED
Details
10685570
08S05
48
.7
ST MARYS FORD
43135
07-JAN-09
00704701
Customer Comments
CUSTOMER STATES PERFORM RECALL 08S05
Tech Comments
. PERFORMED RECALL 08S05. REPALCED BRAKE BOOSTR VACUUM HOSE AND TESTED , OPERATES AS DESIGNED
Details
