I went to test/clean IAC and got 0.015V when I probed wires of the terminals of BPA-ISC. I should get 10.5V. Any other wires I could probe easily to see if my PCM is failing?
So I went to recheck the voltage...When I connect the positive probe to the red wire I get 0.05V and when I connect the negative probe to the other wire (of the electrical hook-up to the IAC valve) it drops even lower (~0.02V). If this means anything, when I ground the negative probe to the battery I get ~12V. Makes me think I have a short in the wiring from PCM to IAC?? I don't know a lot about circuits or electricity, but I am trying.
Results are in and I am confused! Following that website link above i got the same battery voltages from both pins of the electric harness to ground (separately). Resistance on valve checked out. That link is made for a 3 pin, so should i still get the same results (6-8V for one)???
Hot idle was only at 3V between electrical pins that i backprobed while connected to valve.
When i disconnected electric harness while running the idle barely changed but did go lower and definitely ramped up when connected.
Do i have a problem? Im chasing a PIP circuit failure and just checking electrical things nearby.
