No rear bumper?
countryboytn
'78 Bronco owner
4,371
204
Cincinnati, Ohio
So basically, my question is, do you think I'll get pulled over/hassled about no rear bumper on my Bronco?
For those of you who don't know the story, I kinda screwed it up a few days ago while out wheelin' and it looks like crap. This won't be a permanent thing, hopefully less than a few weeks... but I don't feel like getting bothered.
On a side note, I know a lot of the city police, and a few county (my cousin is the chief deputy) so it's not as likely I would get bothered, but still don't feel like getting pulled over. and especially if I go anywhere besides around here.:headbang: What's ya'll opinions?
nobodyspecial
Fire in the hole...
5,756
366
ND
Just leave it on till you get a new one. who cares if its messed up, at leasts its legal. look at how I ran the front bumper on my mountaineer for months:
Yes, that is the actual all the bumper is that hides under the bumper cover. pretty beefy huh? its plastic with Styrofoam in it.
countryboytn
'78 Bronco owner
4,371
204
Cincinnati, Ohio
I do, I can't run my cb antenna or anything, because it was mounted to my bumper. Plus, it looks cool without one (I'm still replacing it though, don't worry)
What I broke...
countryboytn
'78 Bronco owner
4,371
204
Cincinnati, Ohio
Plus, what i forgot to add... the tailgate hits the bumper, when i let it down. so if I did put it back on, I'll have to back into something and straighten it at least a little bit.
nobodyspecial
Fire in the hole...
5,756
366
ND
I don't think you'd get hasseled so much for not having a bumper as much as you would for having an exposed gas tank. I say take a half hour and pund it out as best as you can and leave it on there.
I wouldn't worry about it. I've been cruising around without a bed or a bumper.
I've been pulled over, but just asked how the project was going. (I know too many of the occifers. :D)
Like my grandfather always says: Don't give them a reason to pull you over!
Cough cough...an exposed fuel cell is a valid reason.
What's next? Are you going to tell me that tying my filler necks down to the frame with a coat hanger is illegal too? :D
nobodyspecial
Fire in the hole...
5,756
366
ND
Of course it is, because fuel cells just by them selves are illegal. :D
I think it's safety related when installed on a vehicle, because where the Bronco's fuel tank sits, it's in an awfully precarious spot in the case of getting rear ended.. That's hawked pretty heavily in NC, especially if you have a taller or lifted vehicle. IIRC, TN has similar concerns.
nobodyspecial
Fire in the hole...
5,756
366
ND
you didnt understand me. FUEL CELLS are illegal for road use, not DOT certified.
Ooooooooooh...gotcha now. Yeah, I blew right by that one.
countryboytn
'78 Bronco owner
4,371
204
Cincinnati, Ohio
Alot of customizers have body panels made where the bumper goes. In other words there's no bumper there.
didn't think about that... but it's still a "bumper" I guess?
It's tweaked pretty bad, but not horrible. Do you know where i can get brackets? Checked JBG, with no luck.
I can't drive it right now anyway.... fixing to make a thread on why.
If it's a factory bumper, I've been known to straighten them on the truck with a big (24" or 30") pipe wrench. Be gentle, because it'll want to tear the bumper, but IMO it's better than using the sledge.
*As far as legal stuff...am I right in thinking your rear plate gets mounted to the bumper? That'd guaranteed get you pulled over around here.
countryboytn
'78 Bronco owner
4,371
204
Cincinnati, Ohio
I'll see what I can do with it, I can hopefully straighten it easier off the truck, so I'll try that.. and if not I'll put it back on and try again.
and yep, plates go on the rear bumper, but I just stick it in the backglass. I lost a bolt that holds it, and didn't have time to mess with it.
