- 2
- 0
Hi everyone,im new here! But anyway. My 2006 powerstroke isnt working... so it all started when itlost power and then stopped working on the road and wouldnt start anymore.i pulled it home and the next day i tried starting it. It ran but it was blowing tons of white smoke. So i found out later the egr cooler was failing big time. Replaced that,and then after that i changed the oil. So when i tried cranking it,it cranked fine but wouldnt start. I checked,and there's pressure to the second fuel filter.while i crank it, the oil gauge goes up,showing the low pressure oil side is working.i put my dads computer on it,and it shows while i crank it,the ipr duty cycle goes from 5% to 85-87%?(its been a couple weeks) and the icp shows 0 psi the whole time. I wasnt sure if maybe that sensor wasnt working correctly,so i removed it,and had another person try starting it. First tried cranking for about a second,in case if there was pressure. Then gradually cranked it longer. There is absolutely nothing. And no codes are stored either. Has anyone ran into this problem? Or does anyone have some kind of diagram showing what activates or how this certain hpop work? I have another car to get around but i really want to get it running again
! Please and thanks!
