So I got tired of smelling and hearing my old dual setup outside my doors. So I ordered a Dynomax dual kit for trucks/bronks. Well it was the most poorly designed system I have ever seen. So I ended up changing most of it, so it was the way I wanted it. The lift side pipe came out to the right side of the frame and was supposed to run down the side of the frame then back under to the inside, make it just run parellel to the other pipe. Then That side tailpipe was supposed to run under the right side tailpipe, made it run next to it so it didnt look wierd out the back. The mufflers I put side by side next to the tcast, no it doesnt hit the frame or the skid plate. Sounds awesome, required more work then I wanted to do. Mufflers are Thrush Welded. Also welding the tips on a peice on weld, went through my pants, and boxers to the family jewels, HOTTTTTTT.
Pics and Sound Clip.
1st set of tips
Set of tips from old exhaust, had to cut off lol.
SOUND
1st set of tips
SOUND
