Need some suggestions...
crzybil87
C.R.A.Z.Y.B.I.L.L
Ok so ive been battling out whether to go with a big block or diesel for a while now ...... and Ive decided to stick with my 351 winnie. I think itd be cooler cause no one around me has a built up 351. Now i need some help figuring out what i should do to the motor, i got a set of hedman long tubes on the way picking those up tomorrow, the crank and pistons are gonna stay, so i need help with what cam, intake and heads i should go with, im looking for about 400hp
You will have to get a cam, that is SD friendly, or is yours a carb? Someone will be able to tell what cams will be good. That I dont know myself lol. As heads, some nice Alumn Edelbrocks or something will be good.
You are not going to get 400hp with SD, you will have to convert to MAF and even with that the only way I see you getting 400hp is with a fully built 412 stroker. I could be wrong though about having to have a stroker to get near 400hp though I know I'm right with the SD.
crzybil87
C.R.A.Z.Y.B.I.L.L
Ok but I'm not getting what sd is. I know I may not get 400 but I'm gonna try
SD stands for Speed Densidy, its the way the compter determins how much fuel to add to the engine, when doing mods, it cant compensate as much. MAF reads the amount of air that directly goes into the engine.
4,038
135
Trinity Tx
http://sbftech.com/index.php/topic,18625.0/topicseen.html
Here are the results of my dyno testing on my new 393W.
Components:
A351 Block
Scat Crank
Scat Rods
JE Pistons
Canfield Heads(Out of the Box)
Victor Jr. Intake
Pro-Systems Carb
Camshaft Innovations Hyd. Roller
11:1 Comp Ratio
91 Octane Gas
Results: 532 hp/514 torque
SPECIAL THANKS TO JAY ALLEN!!
I cant copy the graph, but Peak HP is about 5800 and TQ is about 5200...
