need some distributor info
Blue Bomber
Tennessee Chapter member
564
24
Memphis, TN
i need a new (or new to me anyways) dizzy. i want to know if its the same as one on a small block ford. if so i can get a good used one cheap at a speed shop i know of that sells used race stuff. i love walking around that place.
Do you have a parts # or pic to try and determine if it'll work for you? To be honest, I was a little confused by your question so let me see if I have it:
You have a SB, and need a dizzy. You know where you can get a good used dizzy, but aren't sure if it's compatible with your SB? Did I get that right? If so, like I said earlier, a pic, description or part number would be nice.
Another note, do you have a link, name or address for this second hand race shop? If so, I'd like to check it out. Thanks.
Tell me the exact application.
The term small block is not relevant to Fords.You see the 351C./351M/400 would all be considered small blocks
Engine Families is what counts
The Windsor engines or V-90* engines matters.
The 260/289/302 and 351W possibly the same
IIRC, the 351W is a different firing order.
The Distributor for the 240 is different than a 300.
Blue Bomber
564
24
Memphis, TN
wow. i really didnt word my question well. ok, round 2.
I want to either rebuild my 240 six into a 300 or rebuild a used 300. so i was wondering if a 300 dizzy was interchangable with one from say a 302 or 351 ("W","C" or"M").
Blue Bomber
564
24
Memphis, TN
that makes me sad. i guess ill have to get a rebuilt one or something. thanks for the help.
Blue Bomber
564
24
Memphis, TN
Id got to auto zone theyre cheap and theyre new.
they ripped me off on a master cylinder "lifetime warrenty". they couldnt get to my info in the computer. ill never shop there again. but ill look at advance or NAPA.
Blue Bomber
564
24
Memphis, TN
nope. the only ford V8 i want is a 351C. and they are a bit pricey for me right now. other than want, i dont need a V8. i really dont need a truck.
Blue Bomber
564
24
Memphis, TN
ok. ill be working on it for a month or two. ill let you know how i feel about selling it after that.
You could but how would you divide 8 firing points to a 6 cyl engine ? ;)
Blue Bomber
564
24
Memphis, TN
that is a problem. dont they have some kind of adapter??:rofl: :rofl: :rofl:
