need help
4
i have a v 6 that was running on 5 clyders
new plug,wires, coil,injecter #6 cly was running fuel in the cly not spraying it, the ground signal was on all the time for # 6 cly
??? need help ware to go next:
first, check compression, then swap injectors to see if the problem stays with the cylinder or goes with the injector. Possible short to ground on that circuit.
4
i fonund the problem,the computor had a ground singal to the #6 cly on all the time, runnning gas in to the cly all the time the key has on.
replaced the computor, runs good
