Need an idea on scrap weight on a couple trucks
lil_dq
Let 'er eat boys!
6,933
265
Union, MO
Hey all, looking at getting these, for the front axle off the truck.
Any idea on about how much these would weigh for scrap...?
Looking to see if I can make my money back or not.
I would need both to wiegh in at a minimum of 9000. think thats doable?
Also if anyone needs anything off of them let me know. I am going to call on them tomorrow.
Doc...check the 1974 Facts book in the manual subforum...it lists weights
lil_dq
Let 'er eat boys!
6,933
265
Union, MO
Sweet! Thanks
lil_dq
Let 'er eat boys!
6,933
265
Union, MO
I know I got $253 for a stripped down 97 f150. just cab and front end at $200 a ton.
Just trying to see if I could break even or be out only a little for the front axle off the 4x4 and the transfer case.
smokey
Hitech hillbilly
Those old trucks complete right between 5500& 6250 if I remember correct what my 77 & 79 weighTed when I went over the scales hauling rock and coal
lil_dq
Let 'er eat boys!
6,933
265
Union, MO
If that is the case, minus engine and trans I should weigh in at about 3500-4000 then I would think...Might be worth checking out.
Check the book weights!!!!!!!!!!!!!!!!!!!!
1974 F250 4x4 curb weight...4400# ish...they are not as heavy as our old minds think they are!
smokey
Hitech hillbilly
I had 38"tires full heavy wall pipe sliders and brush guard.extra springs and two tanks full of gas.
Probably two hundred or more pounds of tools and other junk in the cab
lil_dq
Let 'er eat boys!
6,933
265
Union, MO
I did!!! LMAO
I think they will be worth the check out any way. You all think there is a market if I parted them out? or just scrap them and move on?
make sure to post pics so we can all get some parts before they're gone forever.
The 76...say 4400 is the weight complete, minus engine puts you in at roughly 3800#'s...minus front axle and tcase you're at about 3400#'s. Minus the bed and front clip you're probably talking 2900#'s. For the 2by, let's say you're talking 4000#'s to start...minus engine and trans, you're looking at about 3250#'s. So now you're talking a combined weight of 6150, last time I scrapped anything (about 6 months ago) I was sitting at $10/100lbs...so you'd be looking at about $615.
Now lets look at the 2by...***IF*** it's a solid bed, you could be talking $500, solid fenders...$50/ea, solid doors...$75/ea. So if you part those out, you could potentially be looking at $750, but how long you'd sit on them I dunno (but those are very reasonable prices if they're solid pieces). Plus the $290 you'd get in scrap for the 76, you could potentially stand to make a few bucks.
lil_dq
Let 'er eat boys!
6,933
265
Union, MO
LOL thats what I did with the 97 i bought. I ended up MAKING $450 off the truck and got my engine, hood, and other misc pieces for free.
I am thinking about going after it.
You're doing this for a Dana 44 ?
Why not find a Dana 60 Front axle instead?
The trucks complete weigh around 4400 lbs
That stripped down truck the way it is would weigh about 1800 lbs M/G
lil_dq
Let 'er eat boys!
6,933
265
Union, MO
I have no need for the Dana 60. The 44 would hold up plenty good on my truck.
primetime
sawmill slave
1,495
64
Onaway Michigan
76 F-150, reg cab, swb, 2wd. No engine or trans, with some stuff in the back, 3000 lbs.
78 Bronco, no engine, trans, transfer case, or axles, nothing in it, 3000 lbs.
78 F-250 4x4, no engine, trans, transfer case, front axle:wasntme: or bed, about 2200 if I remember correctly. Knowing what I know now, that one was worth alot more than the front axle and the $230 I got out of it.
lil_dq
Let 'er eat boys!
6,933
265
Union, MO
Ok would you all take what I need and turn around and sell them again on craigslist?
