need a reverse light wiring harness
I have a 89 f250 with a manual tranny I have the reverse switch in the tranny but I don't have the wiring harness that comes of the main harness or the plug end that plug in the switch.
what happen was! when i purchased the truck from the original owner I never check to see if the lights worked. I new it had other issues like the mounts were all bad. So I replaced then,but when i was down there I noticed the the harness for the reverse lightwere missing. I found were it went when looked at the transfer case i saw what was left of the harness wrapped around it.
so if anyone has a harness and a plug, or nose were i can get one let me know
You could try a Ford dealer...or if it is no longer made, a place like Green Sales.
x2
Since my '90 ZF uses the same reverse switch as my '75 T18 I figure you
shouldn't have any trouble getting a pigtail from a wrecking yard?
BTW, thanks for mentioning that pigtail, it's something I need to add to
the "list of things to do" to my '91 Bronco to get it going. LOL :)
Alvin in AZ
I Got a new reverse light pig tale for my 94.5 ZF at the local autoparts store. was like $8
