Mountaineer engine swap question.
nobodyspecial
Fire in the hole...
5,756
366
ND
I have an interesting idear...
The 302 in my mountaineer is mass air, I have a 351 out of my 95 F150 that is speed density. I am wondering if you guys think it would be possible to swap the 351 into my mountaineer and use the mass air crap to convert the 351.
Do you think its possible? :D
I'm not sure, but I believe there are clearance issues with the heater box swapping a 351 into a Ranger...I'd assume your Mountaineer would be the same.
nobodyspecial
Fire in the hole...
5,756
366
ND
Its been done, space issues can be worked around. My biggest concern is converting the SD 351 to mass air from the 302 parts.
I'm pretty sure if everything electronic is switched over, your computer won't know the difference. I'm not sure about fuel delivery issues because they have different # injectors.
nobodyspecial
Fire in the hole...
5,756
366
ND
...and that should be able to be taken care of with tuning, correct?
nobodyspecial
Fire in the hole...
5,756
366
ND
Sweet. I will log this for the next project. If anybody has any other info, feel free to add it.
nobodyspecial
Fire in the hole...
5,756
366
ND
So, the 5.0 has a cam sensor, and no 5.8s have that. I was told I will run into problems with this.
Anyone know anything about this?
Where is the cam sensor on a 5.0? My 5.8 has a "cam sensor" (notice I put it in quotes because I'm not sure if it's the same as yours; it's kind of a multifunction sensor) inside of the distributor. It's the same piece as the stator, pickup coil, etc... It's got many names.
nobodyspecial
Fire in the hole...
5,756
366
ND
This can explain it better than me. you can see it right on the front, above the water pump. it is driven just like a distributor.
nobodyspecial
Fire in the hole...
5,756
366
ND
and I definitely don't have a distributor. :D
nobodyspecial
Fire in the hole...
5,756
366
ND
yeppers. Thanks 5.0
5.0
FTF'er
1,319
64
In the Middle
Was there ever a 351 that used coil packs? Lighting or Mustang?
nobodyspecial
Fire in the hole...
5,756
366
ND
No idear, maybe someone knows. I did read somewhere that no 351 had that cam sensor, so I am deducing no...
Josh if the 302 is coil packs then I think you might have a hard time changing over that maf computer to the 351...
