- Moderator
- #1
This was taken after #2 injector was replaced. What do you see, and what are your recommendations to the customer?
The 6.0 cylinder numbering is even cylinders on the left and odd numbered ones on the right. Many times a copper washer on one injector will fail allowing compression gasses to get into the fuel rail. This will progressively cause a misfire on each cylinder on that bank as the fuel gets forced away from the injectors. This was not the case for this one though. Look at #7. The ficm strategy on a 6.0 is that it will use neighboring cylinders to compensate for the "lessened" performance of one cylinder. The screen you see has that strategy disabled. Yes, the repair was replacing #3 and #5 with a warning to the customer about the other two.Replace #3 & 5?
139k milesI read about the compensation that the FICM performs. When I was looking at the chart I figured that maybe there was some limitation to the amount that the cylinders could be balanced. That is some good info on the effects of a copper gasket leak! I wish I could remember where I read that.....
How many miles on the truck?
