Mil1on
TexasNomad
FTFS Designated DRINKER!
I know its a 390cid, 2BBL...
But my truck book got wet when the water heater went Nuclear and every thing ran off the pages... :(
Ridgerunner
573
Stillwater Ok
Heck I was told it was a 360.And I don't know how to tell the difference.
2,285
193
Los Angeles
The only way to really tell is to measure the stroke - who knows what someone may have put in there over the years?
360 stroke is 3.5"
390 stroke is 3.78"
The vin says it's a 390
Ridgerunner
573
Stillwater Ok
360 stroke is 3.5"
390 stroke is 3.78"
Steve you just lost me.
2,285
193
Los Angeles
I'm talking about the stroke - the distance the pistons travel from the bottom to the top of the cylinder . The bore diameter of the 360 and the 390 is identical (4.052 standard). The stroke is longer on a 390.
TexasNomad
352 cubic inch
# bore and stroke of 4.00X3.50
# engine for the '58 T-bird
# four barrell carb @ 300 hp
# compression ratio 10.2.:1
# cast iron crankshaft
# forged steel rods, mechanical-lifter camshaft w/machined combustion chambers or cast chambers by 1959.
# By 1960, the 352 HP was available with an aluminum intake manifold producing approximately 360 hp.
360 cubic inch
# Used in Ford trucks
# Lower compression engine with heavy duty internal parts
361 cubic inch (1958 - 1959)
# Bore and stroke 4.0469X3.50
# 10.5:1 compression ratio w/303 hp
# In 1959, the 360 cubic inch used cast chambers reducing compression and horsepower.
390 cubic inch (1961-1976)
# Bore and stroke 4.05X3.78
# Three versions available
# 1961-1963: 390 cubic inch with 9.6:1 compression ratio, four barrell carb @300 hp.
f100
390 2v
ontario truck plant
early 74 model
with a piece of dowel down the spark plug hole
2,285
193
Los Angeles
Take a wooden dowel and stick it in the spark plug hole with the piston at the bottom of the stroke, then mark and remove the dowel. Bring the piston to the top of it's stroke, insert the dowel and mark it again. Measure the distance between the marks. That will be the stroke.
Ridgerunner
573
Stillwater Ok
Thanks Steve
So are you going to do one line post to explain this? 'smiliedoh'
Sorry but I was laying down on the couch leaning over to type on the laptop when I answered.
Steve finished it for me ;)
