metal vrs poly
Lost
PA Chapter leader
3,288
central PA
Well went over truck tallying up what I need to get for next year . Be rust fix or just worn out stuff. DId a core support swap .
And took the spare down . Never been on road by the way .To clean treads and stuff so I could get off easy if needed. And Looks like my rear tank is starting to seep some on strap.
SO metal or poly ? ? To replace it . The poly ussually have couple extra gal capacity . Ow and no rust . My buddy put ones From JC W on and they fit great . They r $50 more than steel .
Metal under $100 bucks last 8 10 year on average (PA ) or more . More than enough to out live the truck . Its a work truck .
This is my favorite body style . And even if get a newer ride probably keep around and redo .I ussually go for whatever lasts longest . And could transplant in other truck .
What ya think?
L:cooldude: st
I like poly.
No rust worries, and I'm told (though I haven't tested it) they're a little more puncture-resistant if you're in the rough stuff, because they're more flexible.
Mostly the rust thing, though- rust through, and also rust flakes inside that plug up fuel filters, etc...
If you're going to keep the truck, or part it out for your next ride, that's what I'd do.
flareside_thunder
7,812
246
Poly got my vote as well....we don't have to deal with rust around here but I'd definitely go poly with the consideration of your geographical location.
Lost
PA Chapter leader
3,288
central PA
Thats what I thought . I dont sell my personal rides they just get reused on other projects .
Thanks bud .
The poly tanks were option on some F350 dually trucks in the 90s
Im cheap, id get a metal and paint it. Hahaha
Lost
PA Chapter leader
3,288
central PA
Actually Painting dose not help much . Most tanks I have replaced look like they rusted worse on inside when I cut them apart (allot like oil pans) . And rust on top where salt cant get to easy .
But a good coat o paint will sure help .
Thanks .
This will be a summer project .
Mr. Stroker
CASE IH
3,121
67
Michigan
My rear tank doesnt work and im also gonna look for a new one this summer. Thinking about doing a rear bronco tank, thats if i can get it in a poly. My spare is in the bed of my truck anyways..
HazzardMadWolf
Go Fast Turn Left
170
Western Ohio
I think i'm going with metal. So that I can get the 38 gal. rear tank and a new 19 gal. front. Can't seem to find the 38 gal. in poly.
