manual hubs opinions?
mtflat
Flatheads Forever
2,559
147
My 86 4x4 half-ton lost the front differential - it definitely had problems - I've been finding chunks of some unidentified metal (not gears) that was wedged between the ring /pinion. I replace it with a junkyard find and everything is good except I still don't have power to the wheels.
Transfer case spins, driveline is turning, axles turn but no drive to the wheels.
Am I right to believe that the hubs are probably toast? Can they be cleaned/rebuilt or should I just go with aftermarket hubs? I'm familiar with Warn - is there a better product I should look for?
countryboytn
'78 Bronco owner
4,371
204
Cincinnati, Ohio
I'd probly go with Warn too, just because they are well known.
I believe Mile Marker is suppossed to be a good brand aswell.
LINK
flareside_thunder
7,812
246
I wouldn't either.....especially for the price. If you plan on doing any type of wheeling...definitely go with the premiums....I like the metal centers better, but I abuse my stuff.
countryboytn
'78 Bronco owner
4,371
204
Cincinnati, Ohio
Yeah, same here. My motto "when in doubt, throttle out" hasn't broken much (yet) but is kinda hard on stuff.
Smokey said that he's popped a mile marker without trying to hard, I've seen a tare down of both of them and they aren't the same.
godblessmud
CHECKERS OR WRECKERS
1,596
63
Moscow, ID
Avoid anything badged mile marker at all costs. winches, hubs, etc...
1985 Ford F-150
Country Boys Can Survive
7,816
307
Tooele, Utah
I had the same problem on my 85 (no power to front wheels or it was intermittantly) got a set of warn premium hubs and have never had the problem again.
mtflat
Flatheads Forever
2,559
147
Update. Got to thinking about the way it went together and....... sure enuf I had the outside gear turned around on both sides. There's no way it will engage that way. Turned them around the correct way and bingo - 4x4 to the dirt.
It's always the dumb stuff.
Thanks again for the hub recommendations but for now I'll keep it stock.
