Looking at a new truck
flareside_thunder
7,812
246
polarbear
just growing older not up
12,878
607
Boring, Oregon
Pretty truck- but a dang 6.0 with a ton of miles, with a big-a** lift, and a ton of $$$'s. Everything I'd avoid all together in one package. For that kind of money, you aren't far away from a BRAND NEW F150 4X4.
flareside_thunder
7,812
246
First off, that's not that much money for that truck around these parts.....Second, I do realize that for being an 07 that is kinda high mileage...but hey, it's a dizzle. Third, the F150's get more and more hideous every year and for the way she wants it decked out....she could get a SD with regular upgrades less the special packages.(ie Lariat, king Ranch, etc.) Fourth, the 150 won't cut the mustard for what she'll need to do with it. The 6.0 isn't a bad engine as long as the EGR cooler has been deleted and it's not been hit with a chip or programmer. Besides, it's what she wants and it's in her budget and within her specifications. What am I supposed to put her in? a 6.4, 5.4 or V10 SD? Yuck.
just minor stuff
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
T/F7 F T/BC T/BD T/E A1 T/BE T/YB 02-JUN-2006 24-SEP-2006 124227 USA 2 6Y05 000001 * MAINT * A99 82 5776
AWS Claim Key: 100883 Trx Code: 0712S Labor Hrs: 1.1
Dlr Cd-Sub Cd: 03073 - * Name: MULLINAX FORD Ph: 407-8897600 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:14-NOV-2006 Doc #:441384A
Cust Comments: FORD ESP MAINTEANCE 7.5K DIESEL OIL AND FILTER CHANGE TIRE ROTATION
Tech Comments: 5776 OIL FILTER W TIRE ROTATION
T/F7 F T/BC T/BD T/E A1 T/BE T/YB 02-JUN-2006 24-SEP-2006 124227 USA 6 6Y05 000001 * MAINT * A99 82 11633
AWS Claim Key: 357267 Trx Code: 0712S Labor Hrs: 1.3
Dlr Cd-Sub Cd: 03073 - * Name: MULLINAX FORD Ph: 407-8897600 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:14-MAR-2007 Doc #:448581A
Tech Comments: 11633 OIL AND FILTER CHANGED TIRES ROTATED MAINTENANCE SERVICE COMPL
T/F7 F T/BC T/BD T/E A1 T/BE T/YB 02-JUN-2006 24-SEP-2006 124227 USA 9 7S22 1801XX * 14526 * A85 42 18091
AWS Claim Key: 682165 Trx Code: S07 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 03073 - * Name: MULLINAX FORD Ph: 407-8897600 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:20-JUN-2007 Doc #:454297E
Cust Comments: A85 CUSTOMER STATES CHECK ELECTRICAL HOOK UP NO RUNNING LAMPS ON TRAILER
Tech Comments: 18091 FUSE 2.38 BLOWN 000 PERFORMED BCE TEST FOUND FUSE 2.38 BLOWN REPLACED FUSE AND CHECKED TRAILER CONNECTOR. RUNNING LAMPS FUNCTIONING PROPERLEY AT CONNECTOR
T/F7 F T/BC T/BD T/E A1 T/BE T/YB 02-JUN-2006 24-SEP-2006 124227 USA 9 6Y05 000001 * MAINT * A99 82 18091
AWS Claim Key: 682164 Trx Code: 0712S Labor Hrs: 1.3
Dlr Cd-Sub Cd: 03073 - * Name: MULLINAX FORD Ph: 407-8897600 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:20-JUN-2007 Doc #:454297A
Cust Comments: FORD ESP PREMIUM 15K SERVICE SEE ATTACHED SCHEDULE 6.0L (M&W)
Tech Comments: 18091 15K ESP MAITENENCE 150 PERFORMED 15K ESP MAINTENANCE LOF. ROTATE AND FUEL FILTERS
T/F7 F T/BC T/BD T/E A1 T/BE T/YB 02-JUN-2006 24-SEP-2006 124227 USA 11 6Y05 000001 * MAINT * A99 82 23590
AWS Claim Key: 912948 Trx Code: 0712S Labor Hrs: 2.2
Dlr Cd-Sub Cd: 03073 - * Name: MULLINAX FORD Ph: 407-8897600 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:13-AUG-2007 Doc #:457457A
Cust Comments: ESP MAINT PERFORM DIESEL 30K MAINT SERVICE MENU ATTACHED
Tech Comments: 23590 PERFORM 30K SERVICE AS PER FORD RECOMMENDED MAINT. OPERATION MB30 2.2 HRS OIL CHANGE TRANS FLIUD CHANGE REPALCE FUEL FILTERS AIR FILTER PERFORM POST ROAD TEST
T/F7 F T/BC T/BD T/E A1 T/BE T/YB 02-JUN-2006 24-SEP-2006 124227 USA 16 6Y05 000001 * MAINT * A99 82 31280
AWS Claim Key: 1642255 Trx Code: 0712S Labor Hrs: 1.5
Dlr Cd-Sub Cd: 03073 - * Name: MULLINAX FORD Ph: 407-8897600 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:28-DEC-2007 Doc #:465917A
Cust Comments: PERFORM 6.0L OIL AND FILTER SERVICE $69.95
Tech Comments: 31280 030 PERFORM 6.0L DIT OIL AND FILTER CHANGE
T/F7 F T/BC T/BD T/E A1 T/BE T/YB 02-JUN-2006 24-SEP-2006 124227 USA 17 6Y05 000001 * MAINT * A99 82 35716
AWS Claim Key: 1884880 Trx Code: 0712S Labor Hrs: 1.1
Dlr Cd-Sub Cd: 03073 - * Name: MULLINAX FORD Ph: 407-8897600 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:07-FEB-2008 Doc #:468318A
Cust Comments: 0712 USA 2006 NEW 60 75000 PREM MAINT(M&W)6.0L DSL 7.5K 37.5K SERVICE OIL AND FILTER CHANGE WITH TIRE ROTATION
Tech Comments: 35716 REPLACED OIL FILTER TIRES ROTATED
T/F7 F T/BC T/BD T/E A1 T/BE T/YB 02-JUN-2006 24-SEP-2006 124227 USA 18 6Y05 000001 * MAINT * A99 82 41257
AWS Claim Key: 2055254 Trx Code: 0712S Labor Hrs: 1.8
Dlr Cd-Sub Cd: 03073 - * Name: MULLINAX FORD Ph: 407-8897600 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:04-MAR-2008 Doc #:469810A
Cust Comments: 0712 USA 2006 NEW 60 75000 PREM MAINT(M&W)6.0L DSL 7.5K 52.5K SERVICE OIL AND FILTER CHANGE WITH TIRE ROTATION
Tech Comments: 41257 PREM MAINT 6 OIL DSL 5K
T/F7 F T/BC T/BD T/E A1 T/BE T/YB 02-JUN-2006 24-SEP-2006 124227 USA 21 6Y05 000001 * MAINT * A99 82 48434
AWS Claim Key: 2675387 Trx Code: 0712S Labor Hrs: 0.8
Dlr Cd-Sub Cd: 03073 - * Name: MULLINAX FORD Ph: 407-8897600 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:30-MAY-2008 Doc #:475302A
Cust Comments: USA 2006 NEW 60 75000 PREM MAINT(M&W)6.0L DSL 7.5K 52.5K SERVICE OIL AND FILTER CHANGE WITH TIRE ROTATION
Tech Comments: 48434 OIL AND FILTER CHANE WITH TIRE ROTAITON
T/F7 F T/BC T/BD T/E A1 T/BE T/YB 02-JUN-2006 24-SEP-2006 124227 USA 22 7H05 120403 7C3Z 19980 GA C02 42 52691
AWS Claim Key: 2964377 Trx Code: 0701D Labor Hrs: 0.7
Dlr Cd-Sub Cd: 03073 - * Name: MULLINAX FORD Ph: 407-8897600 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:10-JUL-2008 Doc #:477521B
Cust Comments: C02 PREMCARE OR DIAG CUST STS AC BLOWER INOP AT TIMES TURN TRUCK OFF THEN BACK ON WILL WORK
Tech Comments: 52691 A C CONTROLL HEAD OPEN INTERNAL OF CONTROLLER CODE 42 CAUSAL 19980 OPS 19700D 19980A VERIFIED AC CONTROLLER SHUTS OFF WITH KEY IN ON POSITION CHECKED FOR POWER AND GROUND PASSED 12.8 VOLTS AT PIN THREE AND 0 OHMS TO GROUND REPLACED A C CONTROLL HEAD AND VERIFIED REPAIR
T/F7 F T/BC T/BD T/E A1 T/BE T/YB 02-JUN-2006 24-SEP-2006 124227 USA 22 7T09 1801XX * 14B192 * P82 42 52691
AWS Claim Key: 2964376 Trx Code: 0701D Labor Hrs: 0.7
Dlr Cd-Sub Cd: 03073 - * Name: MULLINAX FORD Ph: 407-8897600 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:10-JUL-2008 Doc #:477521A
Cust Comments: PREM CARE OR DIAG CUST STS 4X4 INOP DOES NOT ENGAGE
Tech Comments: 52691 RELAY FOR TCASE MOTOR BAD OPEN CIRCUIT INTERNAL OF RELAY CODE 42 CAUSAL 14B192 OPS 7453D 7453D45 INSPECTED AND VERIFIED NO FOUR WHEEL DRIVE TEST FOR CODES FOUND NONE TEST FOR POWER FROM RELAY FOUND NONE COMPONENT TEST RELAY FAILED REPLACED RELAY AND RETEST PASSED TEST SYSTEM PASSED VERIFIED FOUR WHEEL DRIVE NORMAL OPERATION
T/F7 F T/BC T/BD T/E A1 T/BE T/YB 02-JUN-2006 24-SEP-2006 124227 USA 26 5C04 050100 5C3Z 4A376 F K02 42 60995
AWS Claim Key: 3663284 Trx Code: 0701D Labor Hrs: 0.9
Dlr Cd-Sub Cd: 03073 - * Name: MULLINAX FORD Ph: 407-8897600 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:05-NOV-2008 Doc #:483683A
Cust Comments: CUST STATES HEAR A RATTLE TYPE SOUND COMING FROM FT END AREA WHEN GOING THRU BUMPY SANDS ROAD
Tech Comments: 60995 4X4 NOISE FROM UNDER TRUCK 90 ESP 7453D .4 4602B .5 INSP AND PERFORMED 4X4 DIAG NO CODES REPLACED FRT DRIVE SHAFT ASSY
T/F7 F T/BC T/BD T/E A1 T/BE T/YB 02-JUN-2006 24-SEP-2006 124227 USA 26 6Y05 000001 * MAINT * A99 82 60995
AWS Claim Key: 3663283 Trx Code: 0712S Labor Hrs: 2.2
Dlr Cd-Sub Cd: 03073 - * Name: MULLINAX FORD Ph: 407-8897600 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:05-NOV-2008 Doc #:483683C
Cust Comments: SCHEDULED MAINTENANCE; OIL AND FILTER, TIRE ROTATION,21 POINT VEH INSPECTION
Tech Comments: 60995 SCH MAINT 60K PLAN 220 PERFORMED SCH MAINT 60K MB60 2.2 HR.
T/F7 F T/BC T/BD T/E A1 T/BE T/YB 02-JUN-2006 24-SEP-2006 124227 USA 29 5V02 060300 5U2Z 2V001 FA N17 42 69245
AWS Claim Key: 4108716 Trx Code: 0712D Labor Hrs: 0.9
Dlr Cd-Sub Cd: 03073 - * Name: MULLINAX FORD Ph: 407-8897600 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:05-FEB-2009 Doc #:488412C
Cust Comments: C STATES BRAKES SQUEAKS WHEN BRAKING..
Tech Comments: 69245 090 2001BF 0.8, 2001B1FA 0.1. INSPECT FRONT BRAKE DUE TO EXCESSIVE SQUAELING NOISE WHILE BRAKING, REPLACE FRONT PADS DUE TO CRACKED PADS. CUST HAS MAINT AND WEAR POLICY. ROADTEST TO VERIFY REPAIR
T/F7 F T/BC T/BD T/E A1 T/BE T/YB 02-JUN-2006 24-SEP-2006 124227 USA 29 6Y20 000000 * TAP1 * A99 82 69245
AWS Claim Key: 4115584 Trx Code: TAP1 Labor Hrs: 0
Dlr Cd-Sub Cd: 03073 - * Name: MULLINAX FORD Ph: 407-8897600 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:05-FEB-2009 Doc #:488412F
Cust Comments: LAONER ASSISTANCE
Tech Comments: LOANER ASSISTANCE
T/F7 F T/BC T/BD T/E A1 T/BE T/YB 02-JUN-2006 24-SEP-2006 124227 USA 29 6Y05 000001 * MAINT * A99 82 69245
AWS Claim Key: 4101727 Trx Code: 0712S Labor Hrs: 1.3
Dlr Cd-Sub Cd: 03073 - * Name: MULLINAX FORD Ph: 407-8897600 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:05-FEB-2009 Doc #:488412A
Cust Comments: 5000 MILES (8000 KMS) NORMAL SCHEDULED MAINTENANCE L
Tech Comments: 69245 110 PERFORM NORMAL SCHEDULED MAINT 5K. MB5 1.1 HRS
flareside_thunder
7,812
246
Thank you Vince very much. Anything I should look for in particular? Are there any recalls that should have been performed on it in the past that weren't? Going by the fact the guy kept regular maintenance on it and took it in everytime there was an issue......Thanks again.
