Location of horn relay?
5.0
FTF'er
1,319
64
In the Middle
I could find nothing here about the location of a horn relay, but I think I found the answer elsewhere.
Anyway, it looks like the '73 to '76 trucks had a relay mounted on the inside of the fender, located between the starter relay and the firewall.
'78 and '79 trucks with cruise have a horn relay mounted on a brace behind the instrument cluster.
'78 and '79 trucks withOUT cruise have no horn relay at all.
Ok, now can someone confirm that this information is correct?
Thanks.
On my 73 it is on passenger side fender near starter relay
According to the OEM manual "the horn relay used only on vehicles equipped with speed control is located under the instrument to the left of the steering column and is mounted on the outboard attaching screw of the speed control amplifier module"...that came out of a 1979 manual.
I here by confirm the info in post #1
5.0
FTF'er
1,319
64
In the Middle
Thanks for the confirmation, Dennis. I actually found most of that info from posts made by you elsewhere on the interweb. It's in our system now for when somebody searches for it.
5.0
FTF'er
1,319
64
In the Middle
The motion has been passed unanimously.
:rofl:
Blue Bomber
Tennessee Chapter member
564
24
Memphis, TN
that means its time to party now....Right??
:ola:
:bananarb: :bananarb: :bananarb:
bigdance
I assume this also applies to the 79 e series? nd if so, hpw is the horn wired? I picked up a horn button with cruise but my van doesn't have cruise, I just need a horn switch. But the horn works only when I use a wire to it, and the ground wire from the switch gets hot when I press it but no sound
EDIT: I found out by toying around, that I needed to connect the wire that would goto ground when equipped with cruise, to the blue wire that goes to the other terminal (normally used for cruise)...
BKW
Ford Parts Guru
1,896
118
Simi Valley, CA
I assume this also applies to the 79 e series? nd if so, hpw is the horn wired? I picked up a horn button with cruise [confused] but my van doesn't have cruise.
The same thing applies to 1978 and later Econolines, but...
You cannot use a horn pad with Speed Control for non Speed Control, because the horn will not blow.
The following is the correct horn pad:
E7UZ-13A805-A (replaced D9TZ-13A805-A) .. Horn Pad w/Switch / Use without Speed Control.
Applications: 1978/86 F100/350, Bronco & Econoline / 1987/91 Econoline Cut-Away.
78 -79 speed control wiring
Nice picture Dennis!
