light for gear slector
ok so I got a 04 150 fx4 with the center shifter. I just relized the light just went out. I pulled everything apart to get to the bulb. It looks like it was burnt. So my question is can I get a new one anywhere or do I have to go to ford? And has anyone changed one how do you do it. Do you just pull the wires out cause I tried that and it didnt seem like they wanted to budge.
The shifters that I have worked with used lights similar to dash lights. A half turn should bring it out. As far as the light itself, I dont know if its a dealer item or not.
d-kuzmen
Master Ford Tech
2,109
79
Connecticut
smilieIagree smiliewhathesaid Get the number off it and you may possibly get it aftermarket. Bulb should just pull out of the socket. May require a half turn to remove from the shifter itself.
ok i got it the bulb didnt have a number on it but i found the same bulb at autozone didnt cost much and i had to use some plyers to pull it straight up cause it was stuck and and i couldnt get a grip with my fingers but thanks guys.
d-kuzmen
Master Ford Tech
2,109
79
Connecticut
Anytime.. YelloThumbUp
