let's see your custom gauges or mounts! dash ect
86N/A
Clean&Scrub Man
What's been done out there? Not a big fan of the regular 3mounted too the bottom of the dash deal.. I'll be adding a boost, egt, tach and mabey air pressure gauges and not sure on how I'm gonna do it yet
31
Christmas gets people busy.
On my 79 I am going to weld studs on the pillar and mount the important gauges there, when I originally looked at doing it, I figured that it would fit 4 gauges.
Any others will have to go to that crappy place under the dash.
86N/A
Clean&Scrub Man
I'm considering building a small body color shelf for above the windshield and putting the egt and boost up there in the left corner, and mounting the tach to the column
I'm going to replace the stock cluster bulbs with a straight green and use the Autometer Z series that are backlit the same green and they actually sell a diesel tach
I drew a picture but I'll only have the far left 2 the pic I drew had thos then tach then 2 air psi
Also gona put a CB up there if I do the shelf
