LEB customer build 468"
LEB Kris
Kris
449
17
SC
Just thought Id start a couple build threads....
Heres a 468" 9:1 Silvolite or Speed Pro cast pistons(this one is Silvolite), King Bearings, Comp hydraulic flat tappet cam, recurved duraspark, D3 with a mild port job on the exhaust side with Comp springs, retainers and locks to match cam specs, Weiand Stealth intake, Holley 750 vac sec.
Makes 400hp/500tq all day long, runs on 87oct pump gas, has excellent street manners, plenty of vacuum for power brakes and works well with a stock torque converter. A turnkey copy of this engine will run $4000 with a $350 core or exchange. (short block ONLY - block, crank, rods, pistons, King cam main and rod bearings, std volume Melling oil pump and a gasket kit - $1500 with a $250 core). Painted VHT color of choice. Currently we are 6-8 weeks out from start to finish once initial deposit has been paid. Upgrades available at cost.
Fresh from the machine shop with VHT Ford Dark Blue engine enamel
King bearings
Sitting next to #project: Leftovers
Slap the crank in with careful attention paid to the bearings clearances. These were perfectly in spec with a .00294 average.
Pistons on the left - Silvolite cast pistons and file fit Hastings rings on D6VE truck rods with stock bolts
Assembled short block - $1500 + $250 core or exchange
Slide the cam in
Valvetrain components
Assembled with a Cloyes straight up timing set
Missed this, looks good!
