Sorry I guess I should have clarified... The wheel is not moving around at all (not visibly at least). What you're seeing is STRICTLY happening in the tire.el bento rimo
Rear tire on a non-full floating axle. It doesn't have a hub back there. Lugs are the only thing holding it in place.Is the center of the wheel bigger than the round part it fits over on the hub? That would let it wobble by being off center (maybe).
No I don't believe there's a hub back there. Isn't there such a thing as wheel centering lugs?This is a 9", but the round part is what I was talking about. The wheel should fit it. That is what holds the wheel/tire centered.
Maybe your does not have the "hub" (round part) sticking out.
Thats what I thought. Thanks Trav.no hub back there. the wheel is lug centered not hub centered on the axles for these trucks
that can happen when the wheel is warped. Its not bent, just warped.
If you dont believe me jack the back end up and watch the wheel as it turns from side. Looking over the sidewall. it will wiggle or bump.
I believe you have alloy wheels right or alu.? Well you cant tighten them down like steels. You tighten the wheels down snug. Then rotate the tire and wheel while the truck is jacked up and then snug it again.
Do the star tightening pattern.
The acorn style of your lugs how that it has the bevel tip and the rim is beveled in the opposite way. Well when you seat your lugs. It should line up yoru rim just fine.
Have you ever locked up your rear brakes on concrete? that could cause you tire to have a had wear spot.
if you dont properly tighten a alloy wheel or alu wheel. The wont line up and they will become loose.
i worked at a tire shop for a couple of years.
If its the tire. You can have the tire peoples fine the bad spot in the rim. and line up the tire approprietly .
But more than likely your wheels are warped, realy common in steels but can happen in alloys and alu wheels.
if your still paranoid about it. When you get everything set up, give me a call ill try and walk you through it. if you need call me ill pm you my number.
I'm just gonna take it down to Les Schwab
Yeah thats what I plan on doingLes schwab is a pretty good place. Gods of the tire shops. Dont let them short cut you though. Have them rotate the tire on the rim until it calls for less amount of weights.
they will think your an asshole. But its the right way to do it.
