- 5
- 0
Hello all,I would like to thank you for all the past info I have gotten from the posts I have read.
I have recently picked up a 1987 F350 the originally had the 460 in it. Somewhere all the line someone put a 1977 351M which it has in it now. It has the 2 barrel manifold and the carb was in really bad shape so I found a rebuilt motorcraft 2150 and put it on to get it up and running. My problem is when I put the truck into gear(auto trans) it will not even begin to try to hold idle. It dies as if I turned the key off. If I slide it into drive and quickly feather the gas pedal I can get it to run down the road but no matter where I set the time I have the same problem in drive and reverse. It does have a rod coming up from from under the firewall next to throttle cable that looks like it should connect to the carb but I see no place to hook it up. I am not sure where to start first with my problem. Any suggestions would be greatly appreciated.
