I need OD
Mr. Stroker
CASE IH
3,121
67
Michigan
Well my dads superduty is in the novi parking lot tonight, as it will be all weekend untill sunday night.
I had to pull a trailer there without being able to switch out of OD, and id love to be able to hit the button. The button worked when we first bought the truck, then we tried using it, hit the button, nothing, then hit it again and then it would work. Well now it doesnt work at all... Ive had the column plastic off and checked for bad wires, but i couldnt find anything. Is there some certain point at where the wire would be bad? What do they wear through the insulation? or break or come apart? Why does this happen. My dads other superduty's overdrive switch didnt work either...
Id like to try to fix it in the parking lot for the ride home.
blackhat620
You Had to be There
1,687
150
Arizona
How about a little more info. Year of truck, engine etc? Transmissions changed through the years.
Mr. Stroker
CASE IH
3,121
67
Michigan
Sorry its a 2002 F250 4x4 with the 7.3L powerstroke
