I get confused about what goes where...
5.0
FTF'er
1,319
64
In the Middle
Not that you pervs...
What fluid goes in the transmission and the power steering?
Is it Mercon and Type F?
It's a '92 5.0 HO with an AOD.
5.0
FTF'er
1,319
64
In the Middle
Thanks.
Did some of the older Fords use type F for the power steering? It seems like I remember reading that somewhere.
I'm pretty sure the last time Ford suggested using Type F in trannies was back in the 76. Now I think Merc 5 replaces everything.
5.0
FTF'er
1,319
64
In the Middle
I dumped Mercon/Dexron in each, so I guess all is good now.
89frankenford
Grabber Green Consultant
4,547
147
NH
i believe the general fluid used is Dexron/Mercon III for both transmission fluid and PS fluid. i run it in my M5OD and my PS
Ford now recommends Mercon V including those that used Mercon III like my 97 f150.
BKW
Ford Parts Guru
1,896
118
Simi Valley, CA
Type F in C4/C6 thru 1976, Mercon from then on.
Type F in FMX, FX, MX Cruise-O-Matic's, Ford-O-Matic.
Type F P/S fluid 1953 thru at least 1979. Didn't look any further.
