How to replace wheel bearings
Hi, just joined here and need to know how to replace the inner and outer fron wheel bearings and seal on 1996 Ford Ranger extended cab 4x4 with 4 liter engine and auto transmission.
I have the wheels and hubs off and can take the inner bearings out but I want to replace the inner bearings and races as well.
I have already bought the bearings and races and seals just need to know how to proceed from hear.
Thanks
Craig
smokey
Hitech hillbilly
Just pull the rear seal and bearing. the old race comes out pretty easy.
If you sign up at autozone they have a online manual that walks you thru it.
How do i take the brake calipers and the Rotor off?
I signed up at auto zone but cant find the online manual that guides me through this process.
Thanks
Craig
Alright I got it down to the spindle and have used a chisel and happer and liguid wrench to break it loose but still not able to remove it because there is a place located about 3 oclock with what i suppose is part of an abs . How do I remove this Pita?That is the only thing keeping me from removing the spindle.
Craig
smokey
Hitech hillbilly
Could you post a Picture of what you are trying to remove?
If it is the plastic ABS sensor they stick sometimes and need to be broken to get them out.
