How to remove tar?
5.0
FTF'er
1,319
64
In the Middle
I was taking a short cut through the ghetto the other day in my Suburban and hit a road with a lot of hot bubbled up tar/oil on it. Now the side of the Suburban has a LOT of tar on it. What have you used that would be quick and easy to remove the tar?
5.0
FTF'er
1,319
64
In the Middle
I'll try some WD40, thanks.
nobodyspecial
Fire in the hole...
5,756
366
ND
Try tar remover...
5.0
FTF'er
1,319
64
In the Middle
Try tar remover...
Maybe some brand of tar remover is better than others? I tried some in the past that just made a smeary mess... I ended up using gas to clean the mess created from the tar remover.
When it comes right down to it,anything that breaks down an oil by product will work. For tar anything thinner then tar, kerosene ,gas, or (anything that is an oil by product that is thinner then tar). Elbow grease is always helpful ' if you have any left,
"Wankin wastes elbow":nono:
I used (with success) Gunk Clear Coat Safe! Tar-n-Bug remover. It came in a large blue aerosol bottle.
nobodyspecial
Fire in the hole...
5,756
366
ND
I havent had to deal with tar, but for other junk, I have used a rag dipped in gas, works fine for me. If there is a lot, then you might not want to use it all over. Who knows. :)
nobodyspecial
Fire in the hole...
5,756
366
ND
now if only they made a product called ghey gone, Paul. :D
nobodyspecial
Fire in the hole...
5,756
366
ND
Knees, plural. get it straight. Sorry, anything straight is probably impossible for you.
Xylene works good for tar.
