How long should tie rod ends 'last'?
14
Just curious about the 'average' - before either failure or typical life of tie rod ends - inner & outer. I have a 2000 F-150 (V6) and have replaced both sides - passenger side let loose at about 95K, the driver side at about 130K. Luckily, the passenger side just fell off while I was at a local gas station (while parked!), the driver side let loose while driving about 25mph not far from where I live. That was an eye opener...
Is this something that I should consider replacing every 50-75K - just as a preventative measure? Not doing any hard driving, of course you'll have the occasional pot hole you don't see coming.
Since it's a pretty easy job, and pretty inexpensive, anyone replace them as a part of 'scheduled' maintenance?
Since both of mine have let loose (BOTH the outer), I really don't like the thought of losing on driving at 70MPH. :drop:
Depends on construction, maintenance, tire size, style of driving, loading. 100k isnt out of the norm though.
d-kuzmen
Master Ford Tech
2,109
79
Connecticut
smilieIagree smiliewhathesaid Keep in mind this is something that should be checked/inspected every oil change as they usually just don't fall apart they tend to wear and start getting play which you would find when inspecting the front end if left unattended thats when you get problems like you had.
14
I did an oil change yesterday and it seems like the passenger side is 'looser' than the drivers side (the last one I replaced). By loose, I mean I could swivel the end by turning the sleeve. But it didn't appear to be sloppy. Is that acceptable? Because ifin it isn't - I'm gonna change that side again.
The swivel is normal. Grab each side of the tire (3 and 9o'clock) and shake it. There should be no "in and out" play.
