how can you tell in the icp sensor is bad
I was wondering how you can tell when the injection control pressur sensor is bad. I am about the change out my cps in about an hour when the sun gets over the house and on my truck we have snow on the ground and then if i have to i am going to change my icp so how can you tell that the sensor is bad
d-kuzmen
Master Ford Tech
2,109
79
Connecticut
There can be obvious signs, leaking or physicaly broken, the truck could also be idleing wierd either to high or to low, cel on. What problems are you having?
d-kuzmen
Master Ford Tech
2,109
79
Connecticut
Is the check engine light on? Usually the icp won't make it stall (it's not impossible just not as common)
d-kuzmen
Master Ford Tech
2,109
79
Connecticut
I would have the truck scanned anyways, the light doesn't always need to be on to have codes in it. Thats may tell you alittle more about what could be causing your concerns.
ya i am if i can get it to runn long enough to get it down to some were to get it scaned, I am putting in the cps right now i stopped today cause i could not get it out but i am going to finish it tommoro and hope that takes care of it.
A_G
wuh?
3,188
74
Tulsa, Ok
it will have a hard time starting even in warm weather.
