HI and Help!
Hi, I just registerd with this site mainly because i need help!!
I have an 99 ford expedition that acted like the fual pump was out so I replaced it.(after checking the fuses and relays) now it still wont start I cant even hear the fual pump kick on. Im not much of an electrical guy so any help would be apreciated i really dont know where to look from here. O it has the triton 5.4 4X4 XLT
384
I may be wrong but when you replace the fuel pump dot ya have to reset the inertia switch? That switch is design to quit pumping fuel after a wreck.. And whe you replace the pump I think it gets tripped..
I don't remember where it would be at on your truck..
smokey
Hitech hillbilly
No replacing the fuel pump doesnt require a such reset. Chris I think you are in the ballpark of the problem with the inertia switch sure sounds like that might be the problem.
