Hemi's
Whats the point of a hemi? do they realy have anything over any other desings that would make it worth getting some from someone like kasse?
89frankenford
Grabber Green Consultant
4,547
147
NH
well yes and no. there really isnt anything bad about them. the only thing that makes an engine(or the heads to be exact) a Hemi is that the top of the head where the valves sit are in a hemispherical shape (or half circle and round). it makes for a more evenly distributed ignition/fuel delivery into the cylinder
Ok so theres no realy good reason to pay an arm and a leg to get hemi heads for my big block? and i can get good enough of a gain on like edelbrock, trick flo, or any other good manufacture like them? cause i was lookin at boss 9 heads from kasse and the were thousands of dollars.
4,038
135
Trinity Tx
For a street truck nah, you don't need them. But on an all out race engine where your trying to wring out every last scrap of power than yeah, I'd say get them..
On the other hand; IF you have the cash and want to, and your buildng a stroker the definitely yes I'd say get them.. jmho
blackhat620
You Had to be There
1,687
150
Arizona
As Aaron said, it really depends on what you are building the engine for and your budget. Hemi heads are available from very few suppliers and are a custom built item. Kasse specializes in full race engines, he is not really in the market to make your DD go a little faster. Are Hemi heads superior yes in most cases, but as with all things, it really depends on all the components selected for the engine build. Heads, intake, bore, stroke, exhaust, air induction system, cam selected for engine components AND use application (Note: Cam should always be the last thing selected). Engine flow and performance are influenced by all of these things, and you must decide where you want the power band and how the engine/vehicle will be used the majority of the time. After you get the engine figured out you are then going to have to match the drivetrain to the engine again based on usage of the vehicle if you want to maximize performance for use.
Also when you are looking for parts, do not forget Ford Performance Parts and donor parts from your local Salvage yard.
Ok cool i want to build my truck to do everything. to show off on the weekens and go in the hills every once in a while. should i be abel to depend on the old block in my truck now if it isnt damaged or should i look for a brand new oone that i can swap out with when got it built? also i have a 5 speed transmission from ford in it now. Is there places that sell better parts for it that could handel like twice the power im have with the stock 460?
blackhat620
You Had to be There
1,687
150
Arizona
Personally if the old block is sound (have it hot tanked, magnafluxed and sonic check the cylinders) i prefer an old block to a new one because the old block has been "seasoned" and a seasoned block tends to be more durable.
If you have a manual in it now personally is would switch to an auto during the rebuild, either a C6 or 4R100. Auto has multiple benefits over a manual.
Here is a link dedicated to the 460
www.460ford.com/forum
4,038
135
Trinity Tx
I agree 100%
I personally prefer a stick, but it's "user" preference.. (c6 is known for its ability to shrug off abuse.)
^^ the PBB of the ford big block world.. :beer:
4,038
135
Trinity Tx
The c6 does not have an overdrive so definitely so w/ it. I don't know anything about the 4R100..
blackhat620
You Had to be There
1,687
150
Arizona
Ill definately keep that in mind. would my gass milage drop with an auto tho?
Fuel mileage will drop if final drive gearing is different and/or if the engine is not operating within its proper power band when cruising down the highway.
dragogt is correct, the C6 does not have an OD, the E4OD and its replacement the 4R100 have OD. The E4OD & 4R100 where the OD replacement of the C6. When you do your build up you will want to gear your axles so that you get the engine in its power band for your most common application. For example if you want to do serious off roading etc then you will want a lower axle ratio (numerically higher), if you want low rpms at highway cruise then you want a high axle ratio (numerically lower).
Here is a little info on the C6/E4OD/4R100
http://en.wikipedia.org/wiki/Ford_E4OD_transmission
Ok i figured that those rear ends were almost bullet proof. i just gota get one with posi-trac. if i stick with my old 5 speed what can i expect in the line of rebuild kits? will it include new gears along with all the bearings and seals?
blackhat620
You Had to be There
1,687
150
Arizona
Most rebuild kits do not include gears, just bearings and seals. Only need to replace gears if they are bad.
4,038
135
Trinity Tx
It will also drop if you/ he looses the OD..
Why not just get a locker??
