HELP for my buddy
6L PWR
Kansas Chapter member
7,961
255
Osage Beach, MO
2001 7.3L Running BAD - Not on all cylinders.
Codes:
P1670
P1316
P0605
P1274
P1276
Holy schmokes! Any ideas on where to start for him?
p1670 ef feedback signal not detected .....p1316 injector circuit (idm codes detected)...............po605 internal control module rom error.......p1274 high to low side open, cyl 4......p1276 high to low side open, cyl 6. It almost looks like he's got something going on with the connector at the idm (behind the driver wheel well). Possibly the connector as well on the driver side valve cover.
d-kuzmen
Master Ford Tech
2,109
79
Connecticut
I would start at the left valve cover, make sure the connector is cliped, if so pull the valve cover off check the harness under the cover make sure it's locked to the valvecover connector, also make sure it's not melted. Leave the valve cover off, check the bulkhead connector at the left valve cover make sure it didn't chafe any wires. If still nothing, pull left inner fender open at driver door area to access IDM check connector for water, i'd accually remove the idm and shake it making sure nothing is in it. Now if no obvious issue are found i'd replace the valve cover and under cover harness first and try again see how it runs. Also if you like PM me your email address and i'll email you some pinpoint tests if you really wanna get involved....
6L PWR
7,961
255
Osage Beach, MO
Dave, thanks. He's gonna start with Vince's ideas in the morning, if that doesn't work, he'll move on to yours, then if no luck, I'll get back to you.
Thanks to Vince and Dave for the quick replies!!
And to Aaron for reminding everyone that this site is for fun too!
BTW Aaron: 'tool' smilieneenar
6L PWR
7,961
255
Osage Beach, MO
BINGO!! It was loose inside the valve cover. On the outside of the valve cover it has a safety catch to keep from coming unplugged, BUT underneath, it was loose and they plugged it back in, but they said that it seems easy to unplug like there's no safety catch of any kind. Is there supposed to be a catch on the inside plug?
d-kuzmen
Master Ford Tech
2,109
79
Connecticut
It should stay locked. There probably worn may just want to replace them so it doesn't happen again.
