Help for another friend
6L PWR
Kansas Chapter member
7,961
255
Osage Beach, MO
Ok, '98 F-250 7.3L
Code: P-1211
Symptoms: Blue Smoke at start-up
Rough running until warmed-up
Also notice oil in the turbo intake and the associated hoses. Yes, It's had a tuner, but don't know what kind or how high.
Any ideas?
d-kuzmen
Master Ford Tech
2,109
79
Connecticut
Ok, '98 F-250 7.3L
Code: P-1211
Any ideas?
P1211 ICP Not Controllable — Pressure Above/Below Desired
This code can be caused by a few different things, could have a bad ICP sensor, high pressure oil pump or IPR, also can be caused by a leak in the high pressure oil system, have seen this code pop up when theres a fuel pressure issue as well. Would need to have a scan tool on it to see what the ICP sensor is doing. Blue smoke is oil (usually) there could be a injector or 2 with bad orings, pull the fuel filter and see if the fuel is black with oil in it usually oil in the fuel bowl is a good sign of a failed injector orings.
