Heater/AC problems
I have a 99 F-150 4x4. Unable to switch from heat to AC. I feel it is a problem with the door under dash as the vaccum lines appear okay. Any ideas?
Thanks,
Gary
bowtiehatr
Certified Ford Tech
probably a blend door or the actuator. if it is the door it is pretty intrusive with dash removal, but the actuator can be serviced easily.
smilieIagree smiliewhathesaid
bowtiehatr
Certified Ford Tech
the door is relatively in the center, but to gain acess you have to pull the dash and partially dissassemble the evaporator case.
d-kuzmen
Master Ford Tech
2,109
79
Connecticut
If I were you i'd remove the blend door motor and attempt to move the door manualy to see if it's stuck or binding, also plug the motor in and switch temp modes to check the motor operation. PM me your email address I should be able to send you the removal procedure.
