@DNFXDLI I need your help!!!
Dec 19, 2019 Moderator #1 nobodyspecial Fire in the hole... 5,756 366 ND @DNFXDLI I need your help!!!
Dec 19, 2019 Moderator #2 smokey Hitech hillbilly Staff member 13,257 706 Garrett Co. Maryland That magnum fuse just couldn't handle the load.
Dec 19, 2019 #4 fatherdoug Tonto Papadapolous 18,903 663 90 Clicks East of Hell Some guy won a Darwin award several years ago for that very same thing. I think he lost his jewels in the process. The rest of them look okay.
Dec 20, 2019 Moderator #5 heavydoc Instigator Staff member 1,994 70 WNC The blue one is not a fuse but if you wrap it in tin foil it should work [emoji12]. The magnum one still looks like it is carrying some of the load[emoji1787]
Dec 22, 2019 #6 Jasperrc Texas Chapter member 934 37 North Central Texas Yeah, Mythbusters did the whole .22 cartridge as fuse thing as well and shrapnel was certainly an issue.
Dec 22, 2019 #7 CowboyBilly9Mile Charter Member 7,118 442 USA I'm sure that in a pinch, a .357 could be stuffed in where the .22's are now. Sometimes, bigger really is better.
Dec 26, 2019 #8 Blue-Truck-Nut97 crank polisher 551 18 I'm not sure if I'm more annoyed by the 2 but splices with 3 different wire colors, or the wire nut at the fuse block. Sent from my E6810 using Tapatalk
Dec 27, 2019 Moderator #9 heavydoc Instigator Staff member 1,994 70 WNC Thank you Jake, what about the black wire tied with the red in that wire nut[emoji2959]
Dec 27, 2019 #10 Blue-Truck-Nut97 crank polisher 551 18 Yeah, the itty bitty red wire. Not a good feeling. Sent from my E6810 using Tapatalk
