General efi 460 build plan...
So as I've said time and time again, Thunder has been sitting for some time and has been neglected. The time has come to where I can do something about it, it's time to get her back on the road. I'm not planning on an extreme build, relatively mild...but the results should yield 100rwhp...which will put me at the upper limit of the stock fuel system. The following is the general road map I plan on doing getting there, as time allows:
-.020 or .030 engine rebuild kit
-Heads decked .030/block decked .020 to increase squelch and CR
-Open up intake valves to 2.11
-Cam kit...I have a couple in mind, but want to talk with Comp and Lunati for best fit application and/or custom grind...and for a little advice on springs.
-Double roller timing set
-Port match heads/stock intake for better flow
-Thorley Tri-Y's for better flow
Then if I need a little extra help:
-Adjustable fuel pressure regulator for help at WOT
-Custom Tune to get rid of any deadspots or gremlins
Big assembly will definitely be done by myself. Not sure if I'll have access (or ability) for the machining yet, but I have a couple buddies that might be willing to show me. I'm also not sure if I wanna play with the heads (didn't really enjoy taking apart or putting the broncos back together).
So...any of you guys have any suggestions, don't like what you see or have something I need to know or look out for???
Since I'm not an engineer and didn't know exactly how to match the valvetrain up properly, I loved that Comp had the kits ready to go. Why try to outsmart people that are smarter than me?
^^^Agreed...I'm pretty confident in my ability to bolt all this stuff together, but really have no clue what effect each part could/would have at different points in the stream. Hell...none of these numbers or parts were 100% derived by me, I had a generally idea of what needed to happen...but the specifics came from an annual engine masters competitor on 460 ford.
Truckin4life
Texas Chapter Leader
9,037
San Antonio, Texas
I'm out of the loop on BBf now. But there are a few BBf websites. I'm pulling a blank right now.
Conaski is very smart with the efi gig particularly sbf stuff but he could help you out. Rob (monsterbaby)
Could be found on fte very intelligent BBf guy.
1970Custom
They call me Spuds
14,107
447
Middleton, ID
Actually sounds like you're on the right path, those EFI 460s were pretty choked up for emissions reasons so getting them to breath is going to help.
Seth (Proelator), Chris (hotrodTA) and Allen (fordraceboy) are also guys to talk to on BBF stuff. They're on other boards though.
Thanks...haven't seen much of Conanski, and Rob and myself never really had much love for eachother on the other site.
Yeah...I planned on posting up on NWU.
