brentleedragon
Ayeee
First, How can I tell what gear ratio I have on my truck?
Idk if there was a stock for 79 F-150 302 C6...and I can't remember how to check at all.
Second, Tire size how much is gear ratio and tire size combination going to affect higher RPMS?
The reason I ask is I know when I used to run 235/75 R15 that I could climb hills perfectly fine at 65+
About three years ago I got a set of tires that are off the top of my head are 255/70/15. And I haven't honestly driven the truck as much as I used to recently but I do remember when I got them put on and I notice it now that at 65+ the truck seems to not really want to be above that. So up hills my truck kind of pushes itself back down to 55mph. I have a tach on the truck and it seems to be about 2300/2500rpms at 65mph. I will definitely double check the rpms tomorrow when I am driving. But the most point is could my tire size be affecting this a friend of mine pointed out that it could be. I figured i'd ask you guys.
I need new tires and I would like to go to 31x10.5 r15 but I don't want to change ratio or anything so if anything i'll just go back to 235/75 r15. Or is it more likely I have another problem.
