Fumoto Oil Drain Valve
Beachbumcook
Kansas Chapter member
883
38
Kansas City
Here are some pictures of my Fumoto oil drain valve.
It makes changing the oil as easy as 1, 2, 3...
Remove safety spring, slide lever up and over and the teflon sealed movement opens and the oil drains straight out!!!
No more oily hands.... no more stripped drain plugs!!!
I bought mine from dieselsite.com (same place as coolant filter mod) detailed in this forum as well.
Nothing hits the drain valve. It it did, you would have other problems to worry about... like your steering and front end!!! I got the model without the nipple extension... I just don't think it is needed. Also great for when taking oil samples and need to get oil into that small plastic container.
Brian_B
blank
I never ended up with one, but you can buy them direct from fomoto.
I have heard that if you contact them, they will give you a 10% off number to put in when you place an online order. Thats what I was told anyway. confused
Here is their site:
http://www.fumotovalve.com/
Beachbumcook
883
38
Kansas City
Here is their site:
Yes you can and you are 100% correct.
What I liked about the dieselsite.com website is that they offer the drain plug with the "snap-ring" as extra protection... plus I like ordering "stuff" from them.... good/fair pricing and very fast order processing and UPS delivery.
