fuel de-pressure
7,086
459
upst ny
this is probably a polarbear ?? i need to follow the fuel filter advice but i worry about line pessure. is there a de-pressure for the astro Vortex??
What I did on my Ranger should work universally...pull the fuel pump relay, then crank the engine for 15-20 seconds.
Don't know that for a fact, but I don't see why it wouldn't work.
7,086
459
upst ny
but won't there be pressure behind the filter JD? i'm not worried about the front side, i hate having gas or fumes get to me. there is no relay on this rig. my 150 yep, the astro.....
Shouldn't be pressure. On mine, there was some fuel, but I don't think that can be avoided.
I dunno nothin' about Chevies, though, so I can't tell you for sure.
7,086
459
upst ny
gotcha.. i misread your post. just didn't see the "relay" part.....i'd think you on to it. thanks i'll give it a shot.
if no one hears from me i'm BLOWED UP
7,086
459
upst ny
i crossed up relay for inertia switch as i read this last. i don't think i was hammered but it's possible.
i have to get an OBD2 code reader. i now have "chk engine soon" flashing. never had an issue w/this for 2 yrs. i finish the work on the 150.........and the astro starts acting up. i think my wife is cursing me for being a dink all the time we were together!!!!!
oh and of course the filter is original and the fittings look like the hull of the Titanic. they don't make enough liquid wrench for that rust.
i know.....i'll use the MAPP torch.
thanks john & brian
Bob Ayers
North Carolina Chapter member
1,474
111
Durham, NC
I agree! I would think that there is a schrader valve on the fuel rail, like a Ford. If you wrap a rag around it, and open it, that will release the fuel pressure also.
7,086
459
upst ny
^^^ it takes 7 engineers to get the dog coupe out of this thing. i've got all the tools, just to crippled to contort into the positions required to get to all the fasteners.
there is a valve but ....
i'll post a pic after i find where i set my camera down, of what it's like to work from the front. it'll scare the hell out of you.
7,086
459
upst ny
don't use the torch until the gasoline is cleaned up...Ryan
i can't get it apart..there is no gas splashed. there may be some in the line but when i get BLOWED UP, as the fuel filter explodes the last thing i'll say is......R it's your fault dammit.
i pray you know i'm not totally retarded. dumb, yeah, but i know not to use MAPP on a fuel line. i bought a Propane tank. burns much cooler.YelloThumbUp
You crack me up, Carl. :rofl:
Have fun with that filter; hopefully it don't turn out like brake lines where you bust one, then trying to get it out you bust the next, all the way back to where the whole mess starts.
7,086
459
upst ny
john...... that's exactly what will happen. i've no doubt. nor do i expect it to be any more than me still under that thing in Feb. a filter will be lines, then the purge box, then the rail w/injectors, then i'll be wishing i'd set fire and collected. a few 3rd * burns would up the settlement i'd think. but the truck rides sooooo very well. the a/c is ice cold and Sassy loves to sit in mommies truck.
6L PWR
Kansas Chapter member
7,961
255
Osage Beach, MO
Just replumb it in 1/2" copper. A few street 90's and a few feet of straight and you'll be good to go!
7,086
459
upst ny
^^ and i want to do this why???
i was trying to shame you all into doing it for me. i knew better.
So did this ever get done, carl?
If you're that nervous about getting gas on you, dig out that old bicycle pump out of the scrap heap and cut the hose off. Tighten the air chuck on the schrader valve while the other end is in a receptacle.
Or on the ground. remember that whatever you introduce into the groundwater supply will eventually reach Mount Clinton.
