- 1
- 0
Hello again everyone,
I have a 2011 F150 XLT Eco Boost 2WD. March of 2017 while on vacation I noticed a grinding and popping noise in my front end. Took it to the local Midas shop. They test drove it and then put it on the lift. Front left wheel had major play up & down and the right side had play as well. Had both hub assemblies replaced. The mileage at the time was 61,000, just outside of warranty. Complained to the dealership where I bought the truck new from, waste of my breathe. He did look up the part numbers that Midas had installed and they stated that they were OEM parts. 18 months later, My front end is pulling on the right side. I have checked the tire pressure, it was fine, Jacked both sides up and when I give the left side tire a good spin, it rotates about 7 times afterwards until it stops. Did the same for the right side and it spins 3 times before it stops. Removed the brake pads from the right side to make sure that were not dragging and the wheel still feels very stiff when I turn it. The rotor assembly is tight with no play. It appears I have a wheel hub that is dragging. There is no noise when I turn the wheel, but feels stiff. My current mileage is 79,000 miles.
How do I remedy this.............tired of the constant pull to the right when driving....thanks.
