- 2
- 0
hello every one i have a ford 95 f150 4x4 me and my father in law replaced the clutch clutch master and line as well as the slave cylinder all the bearings fly wheel all new now we put it back together and the clutch pedal had a Little trouble coming back up so i bled it when i bleed it i dint pay attention to the reservoir and i drained it also while the bleeder screw was open the clutch pedal was pressed now no matter how Many times i pump the clutch there is no fluid coming out of the bleeder and there is no loss of fluid in the reservoir i saw on you tube that if you take the rod out of the clutch master from inside the truck you should have fluid come out then put it back in when i pulled it out no fluid comes out at all what can i do to bleed it maybe i drained the slave and if so can i get fluid into the slave by pushing fluid in threw the bleeder screw any help would be appreciated thank you
