Ford 1970 3/4 ton w/ 390 - starts then dies
We just bought a Ford 1970 3/4 ton with a 390. Did a carb rebuild, replaced ignition coil and replaced battery.
Its starting up, then after a few seconds... dies. Sometimes it lasts a little longer about 10 seconds or so. Also, sometimes if the gas pedal is pumped it immediately dies.
Any help would be great.
Have you checked things like..
cap
rotor
ensure plug wires are in correct order
fuel quantity test
wizzard351
ride'n on 35's
2,145
120
wi
if its still got the old canister style fuel pump its got a filter in it. if it does save yourself a lot of problems and go to the parts store and get a fuel pump for a 76 with a 360. no more canister problems because that model doesn't have one. you might have to be a little creative makin the lines fit back on but its not bad at all
