FOR SALE: 1956 F100 Custom Cab…running project
rockher_man
King of the Streets
14
Motor City
Dearborn Michiganarea…about 2-miles from Ford World Headquarters…right near Greenfield Village!
Due to unforeseen circumstances I must part with my F100 project…
Bring a trailer and cash and it’s all yours….
Selling as a package. Asking $10,000 or best offer…
I have much more that this in the truck AND NEW parts!
1956 F100 --- Red with White top original 2-tone paint
ALL ORIGINAL truck inside & out except for motor & transmission…
302 – 2-bbl AND C4 transmission pulled from a wrecked 1970 F100…includes extra C4, got it with the truck!
Fiberglass front fenders…they where installed when I purchased the truck!
PARTS LIST: NOT installed...most NEW in BOXES!!!
2nd set of original rear fenders with spare tire cut-out on driver side fender ---almost NO rust
1970 F100 9-INCH rear axle housing with all brackets removed & cleaned up
Ford 9-inch Big (Torino) Bearing Rear Disc Brake Conversion kit…. rotors are 5” x 4 ½” Ford pattern…
Ford Racing Parts # M-4204-F28A, TRAC-LOC Limited Slip, with 1536-steel billet case caps
ALL bearings & gaskets needed to assemble rear pumpkin….
NASCAR Ford 9-inch 3:89 ring and pinion set --- Back-cut gears!… from a NASCAR
team down south....was told it has 1 400-mile race on it...looks PERFECT!
New Dutchman 28-spline Street/Strip axles & retainers with bearings…NEED axle SEALS!
Extra “hooded” Daytona pinion bearing support without races/bearings
1956 Running boards --- need a few repairs
2nd set of “short” cab-length running boards…I was going to use these to repair the long ones!
Total Cost Involved Mustang II style independent front suspension with tubular A-arms and
air springs with sway bar…rotors are 5” x 4 ½” Ford pattern…
No Limit Engineering FAT BAR 4-bar parallel rear suspension with air ride, includes panhard bar!
Accuair Stage II management system with ride height sensors, key
fobs, EVERY option available!!!….best of the best! !...no waiting with
TWO compressors...SWEET KIT!
VIAIR 400C Dual Performance Value Pack compressors… same ones
sold by Accuair!...no waiting with TWO compressors...SWEET KIT!
12-gallon 8-port D.O.T.approved air tank for air ride system
Art Morrison Enterprises 2" x 4" square steel tubing for NOTCHES…..bent the “hard way”…you can view them here……
http://artmorrison.com/layout.php?y=frames/&x=framekit
Look for a section labeled: Special Bends Also Available!
ALSO AVAILABLE!
Probe Industries SRS #10666-030 flat top pistons Net Head Volume (cc) -4.0.
...and...
Clevite Perfect Circle Ring Set: #315-0049-030 1/16" - 1/16" - 3.0mm (std. oil ring)
Early 60’s SMALL BLOCK FORD Buddy Barr/Holley tri power set up!!!...all original...fuel log, oval air
cleaner & a vintage MOON fuel block from the 60’s!…includes THREE rebuild kits from HOLLEY!
SOME PICTURES HERE...
http://s88.photobucket.com/albums/k200/rockher_man/1956%20F100%20PROJECT/
GLWS...Someone will have a nice start
rockher_man
King of the Streets
14
Motor City
Nice Start.....
Thanks man.....I reasearched & designed this project for a
long time and everything is TOP SHELF!....
...that is what I'm hoping for...someone looking for
a READY to GO project!....all ya need is some basic hand tools &
access to a MIG welder...either one to use OR someplace to take it too...
It's just killin' me to have to get rid of this...:headbang: ...but I do not
have a choice!...
rockher_man
King of the Streets
14
Motor City
LOWER price!...asking $8,000.00...OBO!...
Getting close...make an offer...
Cash gets EVERYTHING I have available for this project!...
I forgot to mention I have all new (repop) emblems for the
hood & doors...
-THANKS!...
