foggy plastic headlight covers
That works good on lightly fogged headlights.... I have done many sets and have seen some so bad that I had to start with 400 grit!
polarbear
just growing older not up
12,878
607
Boring, Oregon
Yup. Maguire's makes a headlight polish that works pretty well. I want to meet the fidiot that thought plastic headlight covers was a good idea (as opposed to glass).
Lost
PA Chapter leader
3,288
central PA
Never had luck with any that last. The salt slime make buffing them a weekly job.
Blade
Backwoods boy
4,657
225
In the boonies
another method is using an sos pad and warm water.... make sure its warm water though.. cleans it up right well
polarbear
12,878
607
Boring, Oregon
I'll have to try something on the headlights of my 2000...I wonder how well that Mcguires stuff works.
Works great- do it about once a month, takes less than five minutes.
Dang, I'd be careful with that. One trick I have learned for window glass, though, is use very fine steel wool after you've soaped up the windows. Get's all the road crud/bugs off that normal washing doesn't take away. Especially good after a day's mudding.
BKW
Ford Parts Guru
1,896
118
Simi Valley, CA
Plastic lenses are cheaper to make, more profit for the automakers.
Meguiars PlastX doesn't work anywhere near as well as the old standby-tube toothpaste, which I've been using on plastic for over 40 years.
I just did the lights on my Sentra the other day. After trying PlastX and other compounds on them it came down to them having to be sanded. The plastX did a good job on the yellowed lights on my 97 F150, but the Sentra wasnt yellowed, it was cloudy. I even tried toothpaste on the Sentras headlights, and it did do something that the other rubbing compounds didnt do, it got me a bunch of comments on how minty fresh my car smelled LOL.
00BlueOvalRanger
Old Fart Sharpshooter
1,370
114
Southern Maryland
Flitz!!!!!!!!!!! (And a cotton rag to put it on. . . . paper towels to take it off!)
BKW
Ford Parts Guru
1,896
118
Simi Valley, CA
Be very careful using a buffer on plastic parts as buffers generate heat, and can burn thru plastic in a NY minute.
