Fogging up the windows...
nobodyspecial
Fire in the hole...
5,756
366
ND
My 97 Taurus has been fogging up, it seems as if it is not getting fresh air circulated. If I crack a window it helps, but it is below zero here. :D Where should I start?
make sure that the blend door, is operating correctly. If the recirculate part doesnt work, fogging is possible.
nobodyspecial
Fire in the hole...
5,756
366
ND
ok, not knowing anything about this car besides oil changes, how can I check that out? Both heat and AC work when changing between them. Is there an exterior vent?
nobodyspecial
Fire in the hole...
5,756
366
ND
Nope, everything seems fine.
